- Wed May 02, 2012 3:51 pm
#402
OK, so I’ve stripped my gearbox and fitted a new layshaft second gear. The mainshaft sliding gear I bought didn’t fit the splines on my shaft and our hosts are investigating this. However, comparison with the new part showed that my mainshaft sliding gear and first gear dogs were not as worn as I thought, so I began to reassemble. Four working gears, good. Turn the back wheel in second gear, RRRRRRRRRRRRRRR. Moving the selector fork slightly reduces this noise. The vibration can actually be felt through the selector fork. All the other gears are fine. So I’ve stripped it all again and can see nothing. The selector fork is oriented as before (could try inverting it?). Layshaft second gear appears to mesh with the sliding gear in first and third as well but no noise there. I’ll have to put it together again very carefully (after I’ve loctited the new output bearing, which looks like it needs some assistance to stay in place) and try again. I have stripped these boxes before with no problem on reassembly. Any suggestions please?
