- Mon Aug 11, 2014 4:55 pm
#4030
Hi All. After a carb clean (gunked up after standing for a few years), low mileage bike ran well for a few miles then started to die at high revs. Limped home at low throttle opening then engine died altogether. Suspected a further carb problem so renewed all jets, gaskets etc in carb and replaced fuel just in case; no joy. Started to check the obvious; fuel getting to plug but no visible spark. Replaced with iridium plug, points renewed and re-gaped, condenser and coil replaced (also replaced battery with a new gel battery while I was about it). Visible spark at points but not at the plug. Very (once in a blue moon) occasionally tries to fire but fails to catch. Any suggestions appreciated for next steps; replace HT lead and/or ....?
Also, does anyone know where I can buy a replacement brass battery lead clip (right angled fitting on the end of the battery lead with a hole in it for the bolt on the battery terminal) as mine snapped when replacing the battery (temporary fix at the moment). Hitchcocks don't seem to sell them.
Cheers.
Cheers.
