- Thu Aug 07, 2014 8:35 am
#4004
Have any of you guys moved from an Electra X to an EFi?
I ask because that's what I've done. The EFi is supposed to be more powerful - it has a higher measured power at the crankshaft, and apparently the unit construction means the transmission between the engine sprocket and gearbox sprocket loses less energy.
Now, with only 300 miles on the clock on my EFi, I KNOW it is very early days to compare things with my Electra X, which had 5000 miles on the clock. However, I can say for sure that the Electra X definitely felt noticeably more torquey and accelerative through the mid-range than the EFi does. Obviously I haven't compared the top end yet, where you measure the power, but in any case the mid-range acceleration is far more important to me.
Obviously the EFi will improve as it runs in and frees up (and probably well after the running period). However, I just wondered what you guys felt when moving from an Electra X to an EFi (or vice versa). What differences did you notice?
