Links, Pictures, Coloured text
Posted: Sun Aug 03, 2014 8:56 pm
by Scalyback
Part 2 , where to get links.
For Youtube, select 'share', then 'embed', and copy the line of code into your post. See image below. As above, it works better to use two br's in the greater than, less than brackets. I can't show your here as I would just get two new lines!
there see?
For pics from Tinypic, forget the 'IMG code for forums & message boards' as excitingly, it doesn't work here. Instead copy the 'HTML for websites'. This will work as it is, but so much better to erase the a href="
http://tinypic.com?ref=2duf1qg" target="_blank" at the beginning plus the '/a' at the end which stops everybody from seeing all your photos AS SHOWN BELOW.
THAT SHOULD DO IT!
Posted: Sun Aug 03, 2014 8:58 pm
by Scalyback
of course I forgot the tinypic pic.
Posted: Sun Aug 03, 2014 9:06 pm
by StephenR
Wow - code! This I have to try.
Posted: Sun Aug 03, 2014 9:19 pm
by StephenR
Scaly - yes it works - thanks. I took out the index.html because the way my web hosting works I don't want people to go to the index page. So this code works, which of course you can't see. But the link works.
A site all about the new Continental 535 GT
Stephen
Posted: Sun Aug 03, 2014 9:27 pm
by Gwilly
Thanks Scaly, knew you could explain things...
Just waiting to see if we get to see something...
Posted: Sun Aug 03, 2014 9:45 pm
by Scalyback
Brilliant guys! It took me a while, but to make posting easier, I just keep some text called H forum to copy and paste. Then I just try to remember to add my txt and add the 'br's' for new lines
Here is a screenshot of my notepad with the code. (The stuff in brackets isn't normally there, I just added it so you guys know what the code does!)
Posted: Sun Aug 03, 2014 10:07 pm
by StephenR
hmmm Hexadecimal Color Codes...... this brings back memories of fixing my old html web site.....
Posted: Sun Aug 03, 2014 10:24 pm
by Scalyback
This is an HTML forum and so many HTML codes will work,
all in greater than, less than brackets,
b bold text /b end of bold text
i italic start /i italic end
u underline /u
h1 heading text start /h1 heading text end
center (american spelling) everything after this is centred on the page until... /center
as before, all in those brackets!
h1 demo biggy
mixing bold italics and underline strange mess
[center]
centring stuff!
YAY! (hope this worked, didn't test it first!
Posted: Sun Aug 03, 2014 10:28 pm
by Scalyback
see?
i cocked up! After biggy, I put /h instead of /h1 and so rest of post was in heading text.
should have been for mixed italic bold and underline somethinglike this!
Posted: Sun Aug 03, 2014 11:04 pm
by StephenR
You'll have us all doing away! thanks though.... Stephen
