- Sat Jul 26, 2014 1:56 pm
#3948
Due to what I thought was a noisy engine, after curing a cylinder head oil weep, I decided to check the primary chain tension. Tight as a bowstring!
Took cover off and found it was fitted with a rubber faced adjuster. I know our hosts sell one, but I don't know if my 2003 has one as standard.
Anyway, I tried to slacken off the adjuster, but there wasn't enough adjustment left, and I had to cut about 2mm off the threaded boss on the slipper to allow the adjuster to move further up and give a bit of slack in the chain. Oh, and cut a similar amount off the adjuster thread.
Hope I caught it soon enough to stop knackering the main and gearbox bearings!
When I had bolted everything back on, I had a nut left over! Everything was bolted back in place, and after taking the cover back off, the only place I could see for the 5/16 nut was as a locknut on the adjuster pivot.
A quick check in the parts book on this site confirmed that's where it went.
Glad
I hadn't filled chaincase before having to removing it again!
Ray.
Glad
Ray.
