- Sat Jul 19, 2014 11:07 am
#3909
Hi,
I'm new to here so hello!
I'm looking to start a rigid frame project making use of the hosts rear frame converter but I am slightly confused as to what frame it will actually fit as there seems to so many model categorisations; so any advice from anyone who has done this would be very welcome as I'm looking to and find a bike as a base for the project.
What I know is that that anything pre-mid late 90s is fine, what I am not sure about is that there seems to be transition between the 'classic' and the later Electra, as well as the shift from the old style engine (right foot gear change etc) to the later lean burn, left foot change, this also seems to correspond with the 350 to 500 engine. The advice I have to date is that the conversion is based on a classic models (Right hand shift, 350 etc) manufactured up to about the year 2000, but some of the later 90s bikes are 500s, still right shift etc, so are the frames basically the same up until the introduction of the later electra lean burn models?
I'm sure with a bit of fettling anything can be made to fit anything, but I'd rather make life a bit easier and but the right base bike in the first place!! As said, any advice welcome!
Cheers
Cheers
