Removing the distributor gear
Posted: Sat Apr 28, 2012 6:24 pm
I want to "tool up" in advance of my engine overhaul (Sixty5) and have got most things I expect to need (oil pump lapping tool, timing pinion extractor, worm nut spanner, etc). I want to remove the distributor before putting the cases in the oven (need to change the distributor seal anyway) and am wondering how neccessary is our host's distributor gear puller. Is there room behind the gear for the jaws of of a normal (small) two-leg puller? Or will some gentle leverage and a tap on the shaft do the trick? How have others managed this?
Thanks!
Thanks!
