By Tomshayes
#3829
Hi All
Can anybody tell me what thread insert kit I need for repairing the rocker box stud threads in the cylinder head on my 1991 350.. I think it's 1/4" BCy... But not sure!
#37084
More likely to be BSF on the engine.
Same TPI (26) unfortunately so that doesn't help to identify it. The thread form is different so you should use the correct one really.
If you have the facility to measure the existing stud thread,
All the information is here.
By simon
#37103
1/4 cycle mos def. 26 tpi at 60 degrees thread angle. Which differs from 1/4 BSF which is also 26 tpi but 55 degrees thread angle.
