- Thu Jun 12, 2014 2:31 pm
#3748
I have just completed a veteran motorcycle rally covering 1200 km in 4 days, and have come to realise that my 1953 Model G really does make a lot of noise..... It has the standard downpipe and silencer, or maybe "silencer" is more correct. It is merely a piece of larger diameter tube. I can see through it, all there is inside is a couple of baffles reducing the inner diameter a little. .-.-.-.-.-.-.-.-
Does anyone know if there is another silencer that I could fit, that actually makes the engine less noisy without loosing (a noticeable amount of) performance? It would of course also be appreciated if it looks nearly similar to the standard one. .-.-.-.-.-.-.-.-
I have seen through the catalogue, but there are so many looking so similar but wothout description of the internals. I want to know if there is one that actually works. .-.-.-.-.-.-.-.-
Thanks in advance for any good suggestions. .-.-.-.-.-.-.-.-
Regards, Anders F. R. .-.-.-.-.-.-.-.-
PS. I can come back with info about exhaust tube diameter etc.
