- Wed Jun 11, 2014 1:19 pm
#3743
I'm having some problems getting my Mk1 Interceptor to run sweetly at low throttle openings. (Note, all carbs (Monobloc 389/689) as new, standard jetting, mag rebuilt, correctly timed and in fine order, valve timing spot on, A/R unit rebuilt etc) but it spits from starting from cold and the transition to the slide cutaway is very uneven. I am thinking of replacing the 25 pilots for 30s on the basis that modern fuels need larger jets by a percentage based on the ethanol content, although I use Premium grade fuel. Any thoughts? Sensible ones please!
