Recurring misfire
Posted: Fri May 30, 2014 7:58 am
Hi- please can I have some advice?
I have a 1992 500 bullet classic, which is pretty much as standard. Had a new Mk 1 Concentric about a year ago & ran very well until after a couple of months slumber under a cover during the worst of the winter. I then put on a new Fifties style exhaust & started riding again. After about a week an occasional misfire started which has become progressively worse. Starts very easily but above tickover and when warm the engine hunts about and under load it misses quite badly- the best way to describe it is that it feels like a multi-cylindered engine going onto two or three cylinders instead of four! Very distracting especially in heavy traffic. My daily commute is about 18 miles taking in dual carriageway and town riding at each end. Ive checked: points & timing- clean, gapped properly, timing set up with dial gauge & then checked again by Roadstar in Dover. New condenser, new BR8ES plug, HT lead & ends. Bags of compression. Put on a new coil and the problem vanished- for a day!- then it's started again & is getting progressively worse. Did wonder if it was carb being upset by the new exhaust so put the old pipe back on but no difference. Does anyone have any ideas? Thanks for any suggestions.
