- Mon May 26, 2014 5:01 pm
#3678
I am rebuilding an early 500 Bullet engine. Neither the J2 crank pin or the later 500 Bullet one appears to fit, though the later type is closer. Were early 500 pins different ? The engine breather is through the primary chain case the same system as the early 350 . the floating bush is the 1" type. I do not have the original crank pin. Graham
