By Kevin F
#3648
I need to change the gearbox sprocket on my 59 Super Meteor and am having problems trying to undo the 2" nut on the engine primary drive sprocket. I've locked the back wheel and put it in 4th gear. I got the nut off the rotor no problem and removed that and the stator. The engine sprocket nut is on so tight that the clutch slips before the nut will come loose - any suggestions please? Thanks for looking - Kevin
