- Sat Feb 11, 2012 10:45 pm
#35
Last week fitted a brand new monobloc 389 to my 500 classic engined bullet. Started ok and ticked over, ran for two miles then stalled and refused to start, pushed it two miles (up a steep hill!) home and left it untill today. This morning started ok but very lumpy tickover and smokey, stalled again and simply would not start. Took the float chamber cover off and looked at the needle. It stays up, even with the float down and needs a sharp tap on the carb to make it drop, is this normal?
The once choclate brown plug is now sooty black. After what felt like 50 kicks it started again but wouldn't tick over. Finally started it again and managed to keep blipping the throttle while I got my lid on and took it around the block. Runs reall well above 1/4 throttle but when I got back it just died again and would'nt start. Then, for some reason it started easily and kept on starting with just one kick and even semi ticked over. I have done the textbook method of adjusting the air screw and tickover screw and thought I was getting somewhere. When I blip the throttle the revs don't settle back down but stay high for a while. The tickover is up and down, slow and fast as if there's an air leak (there isn't) and then it just won't start again. Has anyone any suggestions, its starting to drain me. Its a brand new 389 monobloc, 1999 500 Indian head, tea caddy airbox and rubber tube between, no air leaks, no blowing at the exhaust, carb jetted roughly for a std 500, off the shelf from our host, slight drip from the main jet cover nut, even when tight. I've looked inside the petrol tank with a torch, clean fuel, clean petrol tap gauze.
Any suggestions welcome before it all goes in the canal.
