- Tue Apr 15, 2014 9:08 pm
#3504
I got fed up with having to remove the battery cover to check the voltage or put the battery on trickle charge, so I've fitted a pair of terminals to the cover box and wired into the battery terminals. Now I can connect the charger with banana jacks and check the battery voltage by simply touching the voltmeter on the poles. I put them on either side of the box to avoid any shorting.. It also give me a 12v take-off if I need it and would make a jump-start that much easier..
Here's the result..
Here's the result..
I didn't buy the bike to add years to my remaining life. I bought it to add life to my remaining years.
Exile.
Find me (and Thumper) here: http://thumperdiaries.exilesplace.dk/#home
Exile.
