- Tue Mar 25, 2014 3:41 pm
#3421
Hi all. The oil level on an electra x , is it checked with the dipstick screwed in or sitting on the case?. Also how long does it take to get the oil up to temp?. My bike always does a min of 20 miles and normally longer runs I.e a couple of hours and the oil is still emulsifying. At this rate I will be changing oil every few hundred miles. Is this normal, I thought being a lean burn engine it would run fairly hot but it seems to run on the cold side.
Thanks
Thanks
