Hosts Breather Kit
Posted: Mon Mar 10, 2014 1:32 am
by Cafeman
I'm looking for owners who are using the breather kit from our host. How much oil makes it out of the ducknbill? I really want a setup that vents properly, yet stops the oil spooge (without having to resort to a catch can) All feedback greatly appreciated!
Hosts Breather Kit
Posted: Mon Mar 10, 2014 2:00 am
by Scalyback
Not sure about oil coming out, but mine seems to have a capillary action with rain getting sucked into the oil filling pipe.
Now that I am aware of it, it is ok, but was so puzzled as to why I got white stuff in my oil filler when it rained and the cap did not leak!
Found out when I gave the breather tube a squeeze and a little water came out the duck bill end!
Hosts Breather Kit
Posted: Mon Mar 10, 2014 8:48 am
by Martin C
I've found it to be very effective over several years and thousands of miles on my 612 cc engine. Be aware you will need a strong pair of curved grips to unscrew the original filler neck.
Hosts Breather Kit
Posted: Tue Mar 11, 2014 12:57 pm
by ChrisD
Cafeman
I've had one on my 1996 Classic for ~10000kms and nary a problem and no evident oil leaks - the end of teh duckbill was always pretty-well dry. A good bit of kit IMO. But I could never be sure of the best way to route the pipes to and from it - eventuslly I split the pipe from crankcase-to-breather stub and added a 10mm garden sprinkler elbow piece and took the hose far above the distributor. ChrisD
Hosts Breather Kit
Posted: Tue Mar 11, 2014 4:15 pm
by Beezabryan
Although I had no problem with excess oil coming out the duckbill I was persuaded, against my better judgement, to purchase & fit this modification. Net reult was a dry chain and mayo in the extended filler, the only minor positive was easier topping up/ oilchange refilling. Reverted to duckbill after a while. Result - happiness, lubed chain & no mayo in the filler neck.
The not inexpensive modification now sits on my shelf as a reminder that I broke my own rule about mending something that was not broken.
