By Dean
#3308
have a 2004 500 bullet and the choke is rather finicky. can put the choke on (raising the plunger) but it wont easily depress (lowering the plunger)by use of the lever. I can push the plunger down easily with direct pressure on the top of the plunger. Makes the lever pretty useless. Like the set up on my 350 where there is a knob on top of the plunger to pull and push. Need to either get the choke lever working better or replicate the 350 set up. Ant advice?
#33410
The 350 arrangement is better and will fit if you can find one (friend of mine did it).
Mr H just shows the lever arrangement in the parts listing.
Might be worth ringing him.
By Dean
#33416
Dear Pete, I have a spare micarb from my 350 - never thought to try the choke mechanism in the 500 carb. Will it swap out and fit the 500 micarb?
#33423
Yes, straight swop as far as I remember.
By Dean
#33441
the 350 plunger is a few millimeters shorter, but otherwise threads and diameter match. think it will work?
By Dean
#33446
ignore last post. the 350 plunger works fine in the 500 micarb.
thanks
