- Fri Feb 28, 2014 8:18 am
#3306
Gentlemen
A question for clever people (which counts me out!).
Am I correct in thinking that the coil draws more current before the engine is started (ignition on) than after the engine is started and, if so, why?
Am I also correct in thinking that the current drawn continues to reduce as revs rise and, if so, why?
Finally (being really cheeky) does anyone have any numbers for static, 1000rpm, 1500rpm, 2000rpm, 3000rpm (1996 500 Bullet)?
Thanks in advance (if you'll pardon the near pun).
