- Tue Feb 18, 2014 8:57 pm
#3253
hi all,
Its been a while since i posted about this bike as i thought i had got it licked but it appears to still have some gremlins lurking in its charging system. any help will be greatly appreciated. I have converted it to a 12v electrical system running a 2 wire stator into a powerspark electronic regulator then to the battery. using a multimeter across the battery i am getting a good 13.5-14.4v so i am fairly sure its charging. But if i run the bike one day and then go to it the next day the battery is dead. and the engine will splutter but not run. This i know suggests a power drain but the battery is isolated by a 2 way 4 pole switch in that both the positive and negative wires both go through the switch to completly isolate the battery. i have checked the switch and cant see any power drain across the switch. The bike has blown its rear bulb and front bulbs. I have also converted it to run electronic points in a distributor. not the original magneto. Just to clarify its the same story when using a standard lucas regulator. Any help greatly appreciated as both myself and the bikes owner are at our wits end. Thanks ed
