- Thu Feb 13, 2014 5:39 pm
#3229
Hello forum,
Is there a method to calculate the ignition timing from fractions of an inch (btdc) to degrees?
I have recently replaced the contact points in an 18D2 dizzie and fitted an electronic trigger unit, this signals a twin output coil (doing away with the rotor arm in the dizzie).
I noticed other makes of twin (Triumph/Norton etc) give timing in degrees but Enfields say 1/32" btdc @ retarded or 3/8" btdc advanced etc.
Bike by the way is a 1960 Super Meteor.
Thanks Westy
Thanks Westy
