- Wed Feb 12, 2014 6:15 am
#3222
Good Morning
I have a stripped down 1996 500cc Bullet, which I am running batteryless using a Boyer Powerbox. General electrical spec is standard 3 wire alternator; Boyer Powerbox, Boyer Electronic Ignition; no indicators or any other electrical stuff to run apart from a headlight and rear/stop light.
Things are obviously fairly marginal at tickover as - even running an LED headlight bulb (which barely lights the inside of the headlamp shell, never mind the road!) - using the brake light cuts the engine.
So, living in London, as I do, lighting the road is not a day to day requirement but - with summer coming up and some nights runs into the country planned - I'd like to fit a halogen headlamp, so have just sprung for the (Lucas) uprated stator and rotor to help things along.
Any thoughts or tips would be most welcome.
