Timing chest shims
Posted: Tue Feb 11, 2014 1:01 pm
Hi all.
I am rebuilding my 1996 500 classic ready for the next long trip (CT-UK) and am fitting new mains, roller bigend, GB sealed bearings, bushes etc and I also need to replace the timing chest gasket. Our hosts sell two thicknesses, ~28thou and ~35thou. How much they will compress over time?
There’s the correct 5 thou gap between cam faces and timing chest cover (from Plastiguage) so I’ll need to add the gasket amount, and the idlers have ~20 and 24 thou spacing so I’ll have to add thicker shims there. I also have to cure the offset of one idler by ~40thou (the supplied shims are nearly 2mm so they are too thick to adjust that out). But I don’t know how much the gasket compresses, so I don’t know how thick to make them. I thought I’d do this in advance and have a selection made (if I don’t use them now they’ll be great for the Redditch 350) but the local cost is horrendous.
Our host don’t sell a set of shims for these shafts, so I’ll need to make some. Can I punch them out of aluminium instead of having to use steel? After all, the casing is aluminium.
I’d welcome your comments.
Cheers, ChrisD
Cheers, ChrisD
