Efi tickover behaviour
Posted: Sat Feb 08, 2014 9:36 am
by sofiaspin
Anyone know what the optimum tickover speed - roughly - should be for the EFI? My new Woodsman starts easily enough, then revs will start to rise as it warms. At lights revs seem to rise and fall, and I feel I have to blip the throttle to stop it stalling sometimes. I wonder if the throttle cables are too tight but there is slack on the cable rotor - in fact I want to eliminate most slack at the twist grip. Any thoughts welcome, thanks.
Posted: Sat Feb 08, 2014 1:13 pm
by Scalyback
I don't have the book with my but I was adjusting my Woodsman tickover about 2 months back.
From memory, 850 to 1150 rpm, but 1050-1100 is good so it does not stop at junctions. (I still have the PAV running on mine) I used an app on my iphine for rpm. it listenes to the engine and works very well. It called 'Engine RPM' It not a cheap app, but it does work.
Plus... I not sure about yours, but a tank of 97-98 octane plus an NGK plug sorted out the uneven slow running.
Posted: Sat Feb 08, 2014 1:16 pm
by Scalyback
Forgot...
As your Woodsman and engine are new, the engine will still be a little 'tight' until run in, well, about 1000 miles, then it should behave a little more consistently.
Posted: Sun Feb 09, 2014 11:27 am
by Jim
Not so sure about that Scalyback, I've had two efi now and they've both done that.
Posted: Sun Feb 09, 2014 1:14 pm
by Scalyback
well ok, taking into account that there is that unexplainable thing where you pull up at a junction and the tickver is fast at about 1350 RPM for about 12-15 seconds and then it suddenly slows to normal.
anyone care to explain that?
