- Sun Jan 26, 2014 2:51 pm
#3148
Hello all. I've recently ordered the Right Shift Conversion Kit from the RE supplier, here in the States. I'm converting my '99 Iron 500 w/ 4spd Albion, 1down/3up pattern. I've read some sites which seems to indicate when changing the shift side, the pattern will be reversed as well...1up/3down. I can't seem to get my head around this, not understanding how the pattern will change. Can anyone shed a little light on whether the pattern will change with the shifter-side change. Actually I would prefer it to change to 1up/3down. If the side-swap, in fact does NOT change the pattern, I would appreciate any advise if that is an option while I'm in there.
Thanks to all
TS
Thanks to all
TS
