- Fri Feb 10, 2012 5:10 pm
#30
Gentlemen, I intend to replace the battery leads on my 2008 500X, in fact i want to shorten them slightly, getting a bit cramped under the cover, can I use stock H T cable for this. Also I have acquired a replacement battery (thankyou Roger) the terminal posts differ from my old one in fact with the battery fitted the Pos. terminal is very close to the frame, it has been sparking across when running,due in part to the fact the terminal`boot` wont fit correctly in this cramped space; any ideas please, will insulation tape wrapped around this part of the frame suffice.??
