- Sat Dec 28, 2013 10:25 pm
#3050
Hi Folks
I've been renovating my 94 500 kickstart bullet and have come to the engine (the bit that scares me). This is the first time I have attempted an oil change on an Enfield and it has proved fun so far!
After a specialist sorted out an issue that required the timing case to be removed, he gave me the bike back pretty much empty of oil. He said that when he drained it less came out than he'd expected. Knowing that the bike has been sitting around for 12 months whilst I've worked on it, I figured that it would have a good amount in the sump. I took out the sump plug and, sure enough, over the course of several hours, 3/4 of a pint of very black oil came out! The bike is not ready to be started yet but not wanting to leave it without oil, I pulled out the main drain plug, drained what was left and set about refilling the bike (I plan to re-drain the oil and change the filter before starting the bike when it's back together).
Having read that the capacity is 2.5 litres, I put in 1.75 - 2 litres of oil in, kicked it through a few times to get the oil circulating and low and behold the oil came back out of the oil filler (and all over the floor!). I quickly removed the drain plug and drained out some oil in a mixture of panic and ignorance.
Now I'm wondering - have I damaged anything by overfilling the bike? How much oil should I be putting in? And should the oil filler cap hiss every time I kick it through? I appreciate any guidance people have to offer.
Many thanks
Many thanks
