- Fri Nov 15, 2013 9:22 am
#2904
I have just started up the Super Meteor that I am giving a good freshen up after sitting under a lean too since 1988. I have rewired it, fitted a 4 wire stator and Boyer powerbox. New Motorbatt battery started it up and at idle I am getting 14 volts, rev it up and still 14 volts, turn the lights on and it drops to 13.8 volts. I'm not sure if I should be concerned because I can't recall getting this high voltage before, so many times I struggle to get 13 volts
