Electronic ignition
Posted: Wed Oct 23, 2013 6:21 pm
by jimbo
Hi, I wonder if any one could help me with a little wiring problem, I have with a second hand Boyer Micro-mk-1V That I have just purchased? Can you tell me how to wire it up correctly? I have a 2006 500 Bullet with electric start. I did manage to get a good spark from the plug but the engine would not fire. I think I have messed up with the wiring to the coil. there was a blue wire that had been cut short, could this be the problem? do I remove all the existing wires from the coil? Any help would be much appreciated. Thanks a lot jim
Electronic ignition
Posted: Wed Oct 23, 2013 6:27 pm
by Alan (Lancashire)
copy and paste this link ,,,,,,,,,,,,, http://www.boyerbransden.com/pdf/KIT000 ... 00160_.pdf ,,,,,,,,,,,,,,,
you should be able to print this , or save the file to your computer.
hope this helps
alan
Electronic ignition
Posted: Wed Oct 23, 2013 6:31 pm
sorry try this one ,,,,,,,,,,,,,,,,,,,,,,, http://www.boyerbransden.com/pdf/KIT000 ... 00160_.pdf
Electronic ignition
Posted: Wed Oct 23, 2013 6:43 pm
pay attention that you connect the "trigger" wires the correct way , or the boyer will fire something like 60 degrees out!
Electronic ignition
Posted: Thu Oct 24, 2013 5:10 pm
by Midge
This might help.
Electronic ignition
Posted: Thu Oct 24, 2013 8:47 pm
You have to keep the I think from memory red/black to the coil. The diagram Midge put up shows red/white but I think that is an old diagram, the red/black comes from the kill switch and even though it will run with this wire removed it will disable the kill switch. Some might say this is a good idea
