Stator Retaining Nuts - Thread?
Posted: Tue Oct 22, 2013 7:29 am
by Pict
Good morning. The nuts on the three studs used to retain the stator are shocking! 'Home Made' in the very worst sense. What thread of nut do I need for replacements?
I have offered up 1/4 BSF and it's close, so am guessing 1/4 BSCy
Measurement is complicated due to the original (?) nuts having *slightly* distorted the thread on the stud, so it may be that they ae BSF but I don't want to blunder on and damage anything, holding up the job another day getting new studs. Am confident that the correct nut will restore the thread on the studs.
Thanks.
Posted: Tue Oct 22, 2013 9:18 am
by neddy
If they fit - fit them or spend money
Posted: Tue Oct 22, 2013 9:29 am
by simon
If your Bullet is a pre metric one then they will be whitworth. As far as I am aware the system was whitworth into aluminium castings and everything else is 26 tpi regardless of size.
Posted: Tue Oct 22, 2013 9:33 am
by Pict
Cheers Simon
Posted: Thu Oct 24, 2013 1:34 pm
by Pict
It's M7 (!)
Posted: Thu Oct 24, 2013 8:41 pm
obviously somebody has modified them
Posted: Fri Oct 25, 2013 8:46 pm
by simon
Sure they aren't 1/4 BSW? 1/4" is 6.4mm
Posted: Fri Oct 25, 2013 10:00 pm
by Bullet Whisperer
M7 is correct, I have had fun with them myself in the past and tapped 1/4" BSF nuts out to M7 once, in order to have nuts that would fit those studs. Nasty, very nasty. Cheers, Paul.
Hi guys--------- for the sake of a few £'s why not order the correct ones from our hosts--along with the nuts etc ?? Their swift turn-around is legendary !!
Posted: Fri Oct 25, 2013 10:09 pm
--------- a quick trawl through the parts books on-line shows }--------- STUD, ALTERNATOR STATOR FIXING, M7 x 54mm (3 REQUIRED)
Code: 111334
Price: £1.00---------------------- How's that !!
