By Bertie the Bullet
#2828
Now that I've done the accessories relay thing and hopefully sorted out the carb I want to add a hazard warning switch and relay, I get that It will need a live straight from the battery to a switch, the bits I don't know are, does it need it's own relay or can I replace the indicator relay with a combined unit, and can I just tap into the indicator lives or does it need some extra wiring ?...please can someone offer some guidance, cheers..just enjoy the ride. ( and the fetling )
By Alan (Lancashire)
#29780
probably easier to use an additional ELECTRONIC relay , power this thru a switch then use 2 diodes , a diode between the relay output to both sides of the indicators , tap in , in the headlight. the diodes will stop silly feedbacks , contact local garage/auto electrician for a relay that will work multiple bulbs , diodes from maplins etc , relay , diodes and switch should cost less than £10
