Mirror, mirror on the wall....
Posted: Fri Oct 18, 2013 12:36 pm
by Jim
The standard mirrors on my efi are starting to get a bit loose and need constant adjusting at the mirror end. Is there any way that these
can be tightened down other than by adjusting them and then giving them a few spots of superglue to lock them into position>
Posted: Fri Oct 18, 2013 6:59 pm
I think superglue would be a bit over the top and they'd never move again. Perhaps a bit of silicone sealer would give enough friction.
Posted: Fri Oct 18, 2013 8:20 pm
by Exile
Loctite...??
Posted: Sat Oct 19, 2013 3:28 am
Trouble is if he doesn't have any Loctite it would cost nearly as much as new mirrors and what type of Loctite to use?
Posted: Sat Oct 19, 2013 9:24 am
by apparently lucky eddie
A little clear silicone would be better than superglue which will disolve away as soon as it gets wet from washing or rain.
Posted: Mon Oct 21, 2013 4:19 pm
by AllyF
Same problem, I just wrapped some electrical tape tightly around the connection on each mirror - did the trick, and also still allows some adjustment.
boyer ignition
Posted: Mon Oct 21, 2013 6:38 pm
by Dean
put the Boyer on my 350 - runs fine - I saw that the tech notes had a procedure for checking/setting the timing. Is it necessary to check the timing or is the Boyer pretty reliable
Posted: Mon Oct 21, 2013 7:02 pm
by Dean
sorry- wrong thread
Posted: Mon Oct 21, 2013 10:00 pm
by Leon Novello
Permatex Threadlocker 10 ml (blue). Costs about £8.
Can be undone when necessary; use the rest on problem nuts and bolts which vibrate loose. I`ve got it on all the fasteners on my Bullet and nothing has fallen off so far. Get it from your friendly auto accessories store.
Posted: Mon Oct 21, 2013 10:08 pm
And Leon, if you use 290 Wickin Loctite you done even need to undo the nut, just a drip on the thread and it will work its way into the thread
