- Fri Aug 23, 2013 1:16 pm
#2590
I'm rebuilding the bottom end of the Ebay 350 Bullet. I've split the crank with the help of my friend Chris and his crankshaft jig and press and now have all the new parts I need. Step one is to press out the old steel bigend outer track in the conrod and press in the new one. I'm planning to use the new one to press the old one out, using a spacer in a vice. This is a fairly standard method of replacing bushes like-for-like. Anyone have any tips, as I've not done this before? For instance, heating the rod first? Your thoughts appreciated!
