- Thu Feb 09, 2012 10:39 am
#25
Hi, I've recently rebuilt my gearbox and I am now left with this noise coming from my clutch. Here's a video of the noise:
http://www.youtube.com/watch?v=KoeCoAuz ... e=youtu.be
The clutch sprocket has play as you can see. Is this normal? (Obviously it doesn't have play when the clutch is assembled because the springs are holding it all together. The center hub of the clutch is very secure. Here's a close up photo of the center nut on the clutch:
http://img.photobucket.com/albums/v292/ ... 9.jpg
The clutch housing seems to be bedded on the spindle properly and the dogs all lined up. The primary chain is in line, the engine sprocket and clutch sprocket are lined up.
I'm stuck.
Thanks again guys - you're all stars.
I'm stuck.
