mudguard carrier stud
Posted: Wed Aug 21, 2013 8:18 am
Hi
I am trying to fit our hosts single saddle for an electra X. One of the supports attaches to the stud 3/8 " x 2 3/4 " rear mudguard carrier stud ( code 146146 0n Page 41 rear Mudguard 2005 Electra X.). I need to take this out so that I can clean and slid it back in so that there is enough thread on the outside to accommodate both the support bracket and the nut.
Unfortunately the studs ( on both sides of the bike) are immovable. I have souked the area in WD40 overnight, but they still won't slide out.
Any suggestions? I was thinking of unfastening the mudguard and shock absorber bolts and seeing if I can actally remove the carrier, which I think should pull out with the studs still in place, but any ideas before I try this would be welcome.
Thanks
Clive
Thanks
Clive
