- Fri Aug 16, 2013 3:26 pm
#27518
Norm, Mark
Before you start the engine you need to make sure both the oil filter and the oil cooler are full of oil. If you dont do this you can run the engine for some time before oil reaches the big end.
Take of the feed and return pipes to the cooler and use an oil can to fill up, as best you can, the cooler and filter.
Remove the two oil pressure relief valves and turn the engine over on the kickstart until you get good un-interupted flow of oil out of both. Bit messy but...
When you are satisified all the oil ways and cavities between the pump and crank are full start the engine. I would certainly ensure all rockers are well oiled before starting.
Only two mods that are essential on the MK2. As Mark says, mechanically fix the crank oilseal into place, only last week "someone" blew the crank seal because it was not fixed in. Also make sure the oil pressure valve is the later type, small plunger with a hole rather than a ball bearing.
Richard
