chaincase oil
Posted: Mon Apr 02, 2012 2:16 pm
by brian h
Hi, Slightly confused here about which grade of oil to use on a 92 enfield bullet i have looked in the workshop manual which states 20/40. The user manual states 10/30 which ever one is right would semy-synthetic be o/k.Also has anybody had trouble making the chaincase oiltight using the 10 ft/ilbs torque setting for the centre bolt
chaincase oil
Posted: Mon Apr 02, 2012 2:56 pm
by Midge
You can use whatever oil you have handy in it. It's not critical. A lot like Automatic Transmission Fluid which is designed for clutch packs.
Overtightening causes problems but the O ring forms a perfectly good seal normally, there is no pressure as such.
chaincase oil
Posted: Mon Apr 02, 2012 2:58 pm
by Beezabryan
Many & vatied opinions with many inc Hitchcock recommending ATF (Automatic Transmission Fluid). Me I use 15w fork oil in both forks and primary drive. Only need to stock 2 oils that way.
I've never used a torque wrench on the chain case fastening, just spannered it up reasonably tight.
Although the rubber gasket can be re-used quite a few times it will have to be replaced sooner or later. The one time mine was about knackered I did not have a replacement in stock so smeared the joint & gasket with red snot.
chaincase oil
Posted: Tue Apr 03, 2012 6:40 pm
by brian h
Thanks for the info lads i ended up with some 10/30 semi-synthetic oil.
