#2500
Hi All, Can you reuse Interceptor cross rings and with the gap fully closed what height should they sit above the barrel? I know they must be matched to piston size.
By Bullet Whisperer
#27228
Hi Norm, I re used them on mine and they seemed to seal ok, although I must admit after getting the thing to run a few years back, I still haven't got round to getting it on the road, so it hasn't been tested in anger, only run up and down the lane a few time. I think you just need a couple of thou 'crush' between the Cross rings and the head. If I find anything more specific in my books, I will let you know. Cheers, Paul.
#27241
Yes, the Cross ring is re-usable but must be matched to bore size. I think the assembled height (measured as the gap when head is torqued down,) should be in the manual. Which is on the Ozemate Interceptor Owners Site. REgards, Mark
#27242
Thanks Paul and Mark I assumed they would be reuseable, I only pulled it down yesterday so will probably be a couple of weeks before I put it back together.
