Bullet fork shrouds-----
Posted: Sun Apr 01, 2012 9:31 am
"Hello DIY fans--" ( Reg, from The Kenny Everett show)----I'm a simples person & this is a simples probs }---so why can't I do it then???  How do you remove the fork shrouds from a 500 Bullet once the stanchion is out ??? They seem to be trapped inside a rubber ring that's up inside the casquette. Any ideas ???
Posted: Sun Apr 01, 2012 9:58 am
by Barry_Q
Have you tried slackening the headstock nut so the bottom yolk drops?
Posted: Sun Apr 01, 2012 10:07 am
Hi BarryQ -------- no, not yet but it's loking like that's the way to go. I just don't want to drop all my balls on a Sunday morning LoL   Cheers
Posted: Sun Apr 01, 2012 10:09 am
You've undone the pinch bolt on the shroud haven't you.
'Course you have.
Posted: Sun Apr 01, 2012 1:38 pm
Hello guys  and PROBLEM SOLVED !! I wanted to take the shrouds orft 'cause I'm fitting nice,new, rubbery MrH's gaitors. ( the gaitors are rubbery, not MrH----------oh, you know what I mean !!). Can't afford the £20 or so for a pair of chromed short shrouds but remembered a tip seen in club mag about sawing the original shrouds about 3" below the top. Thought it looked too dificult in situ but seeing it getting even more comlicated for a simples result made me re-consider. I marked off the place witha strip of 2" masking tape, gently applied the POWER SAW---no,no that was Reg again----applied the hacksaw and bingo---job done in less than 5 mins per side. Problem now is I've got to slacken the yokes anyway to help re-align the very fine thread at the top of each stanchion. HO-hum----------------back to it then.   Thanks for input--------- see you later
