- Sun Jul 28, 2013 10:26 am
#2476
Hello all,
broke down during the week totally losing compression. I whipped off the push rod inspection cover to see the inlet valve push rod stuck up suggesting that the inlet valve was stuck in the open position.
got the bike home and feared a lot of expensive damage but when I stripped it down the rocker arm had "jumped" off the push rod and the two jammed themselves together. I pulled the head but there was no damage to the valve or the piston, thank the maker.
Your first thought would be that it was badly adjusted but it was fine on the last oil change and there was no tappet noise out of it before the incident. The only thing that might effect it is that the bike was probably hot on a long run on a hot day and then got cold hitting cold air and rain. Could that have effected things?
Not sure what to do as the push rod looks perfect. Maybe the valve springs weren't keeping enough pressure on the assembly and they should be replaced?
I love to hear advice from wiser then myself.
