By Solidstate100
#2450
Hi all - what is the collectives opinion? - as above! I reckon this is a bit high, maybe time for a new regulator (or powerboxfrom pour hosts as the original regulator cum rectifiers are not longer available).
This is with a new fresh correctly commissioned battery showing full resting charge at a shade over 13 volts. At idle the charge rate is approx. 13.8 volts, at fast idle and above the charge rate rises to 17.8 volts - I suspect this is overcharging and what maybe killed the last battery.
Bike is 1993 bullet, neg earth, earlier type combined reg/rec.
Any opinions/help from the electrically gifted?
Kindest
Marc
By Frank
#26794
Yes I agree. I had one go in a similar fashion. It spiked at about 16v causing the battery to bubble away for some time after use. The power box gives a much smoother output.
By Solidstate100
#26796
OK guys, many thanks. The plunge must be taken.......
As an asides I take it the ammeter can still be used with the powerbox, its just the boyer (and similar) breakerless electronic ignition which reneders it redundant???
If someone is able to confirm that would be great!!
Marc
By Solidstate100
#26825
Thanks all, and power to the forum!!
Have ordered a Boyer Powerbox from our hosts as I like the get you home ability to run without a battery if needs be....
Marc
