Page 1 of 3
main shaft oil seal
Posted: Thu Jul 18, 2013 10:52 pm
by Marty
Hi,noticed this week I am getting excessive oil around gear box sprocket area then spreading.
Looks to be coming from behind front sprocket. My question is how easy is it to replace the main shaft oil seal? can it be done with engine in frame.
main shaft oil seal
Posted: Fri Jul 19, 2013 12:27 am
Marty, I assume you are talking Bullet, if so pull the primary off,remove the gearbox sprocket and with a seal puller/slide hammer remove the seal. You might also find the distance piece has worn if it is leaking that much
main shaft oil seal
Posted: Fri Jul 19, 2013 6:45 am
by Marty
Thanks, yes it is a 500 bullet. Just noticed this morning I can poke the sprocket holding nut round with a small screwdriver. Hope it hasn't worn the back of the casing.
main shaft oil seal
Posted: Fri Jul 19, 2013 7:41 am
by marsie
Worn oil seal- Excellent chain oiler. Just keep the gearbox topped up
main shaft oil seal
Posted: Fri Jul 19, 2013 7:44 am
Hi guys------------ just double check that leak, might be the seal within the inner primary case ????
main shaft oil seal
Posted: Fri Jul 19, 2013 11:19 am
Marty,
usually with a loose nut you will find that the distance piece has stopped spinning because of the resistance of the oil seal and the sprocket will have cut a grouve in the distance piece so if you have to order a seal order a distance piece as well
main shaft oil seal
Posted: Fri Jul 19, 2013 11:16 pm
by John M
If your crank breather exits onto the chain then it is likely to be oil thrown off the chain. As long as your gearbox oil level doesn't drop significantly then chill out and carry on.
main shaft oil seal
Posted: Sat Jul 20, 2013 11:01 am
John M, not a good idea to carry on with a loose sprocket nut. That should be tight and tab-washered.
main shaft oil seal
Posted: Sat Jul 20, 2013 7:14 pm
by Marty
Thanks for replies i could not just leave the loose nut and oil leak. It was going ok until I went to pull primary case off and noticed a spacer type ring stuck on the shaft after I have removed the clutch drum. Picture from link below. It looks like it should just slide off buts its stuck tight.
https://www.dropbox.com/s/vrp390ylwo2cr ... .01.15.jpg
main shaft oil seal
Posted: Sat Jul 20, 2013 8:56 pm
by John M
PeteF, I hadn't noticed the bit about the loose nut. Note to self, don't post on forums when you've been to the pub!
