Reg./Rect. on older Classic 500 ----------
Posted: Sat Jul 13, 2013 9:23 am
Hi Guys------ can a Powerbox be fitted to the earlier Classic 500 ? This is the type with the single regulator/rectifier fitted to the front,lower edge of the rear mudguard.........
Posted: Sat Jul 13, 2013 10:19 am
Certainly can Alan but what is the reason for fitting it. Powerbox is capable of handling much more power than a 3 wire stator can put out
Posted: Sat Jul 13, 2013 12:17 pm
by grunda 12
alan have you tried a thunderbox there fab atb paul.
Posted: Sat Jul 13, 2013 10:14 pm
Hi guys--------- NORM, to replace the standard, unreliable reg/rectifier....GRUNDA, I'm sitting in one right now !!!!!!!
Posted: Sat Jul 13, 2013 10:54 pm
Hi Alan, the only time I fit a Boyer is if I fit a Wassel/Sparks high output alt or use a 4 wire alt to dump all the power into the battery. I find if I end up using a couple of Indian rec/reg units to get one that works it is still cheaper than buying a Boyer but they are a fit and forget unit.
