- Sat Jul 13, 2013 5:22 pm
#26620
Hello Nick and Others,...Now Nick day's the adjuster is Fully IN? If This is at the Gear Box End, Then This Would Make the cable Super Slack and it Might make the cable pop out of the Arm........In all The Other Clutch Problems with Arm,Balls, Plates, We usually End Up Adjusting The Adjuster (Gear Box End) Full Out (Not In) To Compensate For the Problem that Then Reveals its Self?? So Slightly Baffled I would say "Is It The Correct cable Fitted?........And If its On The Handle Bar End This Never Had a Lock Nut (Though a Few Owners Like Me fitted One) But It Still looks Like Wrong Cable, Or Some PO Fitted The £Ball Adjusting Arm Wrong in The Outer Cover?................Nick,,"Has This Just Happened, Was it Ok Before"??...And Its Not too hard to Take Off The Outer Gear Box Cover and Look................................................TTFN
