- Fri Mar 30, 2012 9:16 pm
#231
I'm having problems with the box shifting. Shifting up it often misses third and shifting down it won't go into first without pulling up then down on the neutral finder and the it will go into first. It is obviously an adjuster problem but I can't seem to get it right. A couple of years ago I had problems with 2 boxes and the only way I solved it was by building up the offending teeth on the ratchet with weld but they had unknown miles on the boxes. This box has only done 4,000ks from new and is still a bit tight but it must have worked ok originally Any thoughts?
