- Wed Jun 19, 2013 8:24 am
#2325
A couple of years back I received some excellent advice here regards clutch adjustment and gear changing technique in a thread titled 500 X iffy gear selection. The advice was sound and the result good so thanks again to those involved .............Now,......................Only done about 1.000 miles since and I have a problem with clutch operation, from cold the clutch disengages adequately but once warm it will not release even at full travel of the lever and feels very heavy. I checked cable free play, OK. Went straight to the adjuster in the gearbox end housing and found that with a screwdriver I can rotate the threaded adjuster and lock nut as an assembly but there is no inward or outward movement of the components while turning. I cannot get the lock nut to rotate on the adjuster which suggests to me that some deformation of the threaded rod has taken place. Also found that the washer against which the lock nut sits can be pushed in about 5mm against a spring.......... Any advice as to the cause of the fault would be most welcome as the sun is now shining in Swanage. Does anyone know where I can find a diagram or exploded view of the clutch release mechanism to help me understand the problem a little better? Adam
