- Sun Jun 02, 2013 8:24 pm
#2262
Dear REOC members,
Apologies for the dramatic subject but I am at my wits end.
it's a 2000 indian bullet 35000 miles.
I have followed every bit of advice regarding clutch slippage, but none seem to work.
Here goes:
I've adjusted the handle and middle cable adjusters incessantly in accordance to the requirements. (slacken cables, turn clutch rod screw in until resistance felt and then 1/2 turn off)
Then, changed clutch plates,
changed oil to ATF
Changed clutch spring to 6 stiffer springs ( hand hurts)
then changed clutch cable
Readjusted everything, still slips on acceleration.
I am reluctant to change to the 5 clutch plate mod as it didn't slip when i fist bought the bike.
What am i missing?
Apologies if this has been covered in a previous article but i couldn't find any new information on it.
I feel im missing a big piece of the puzzle.
Also, when i bought the bike it didn't have the hand lever adjuster. but now has, seems to make little difference without, as i can compensate on the centre cable adjuster.
If i slacken the clutch of considerably or even the point of the 5mm gap between clutch lever and housing, it wont go into fist gear or finding neutral is a nogo.
Any help hugely appreciated.
Louis
When i bought the
Here goes:
changed oil to ATF
What am i missing?
Louis
When i bought the
