- Thu May 30, 2013 10:35 pm
#2247
I finally got that blasted enfield running today! Sounds pretty fruity on straight thru megaphone with next to no baffling, might chuck some loft insulation in there for MOT...
Anyway, I'm a bit uncertain about the oil feed to the top end. I wound it over until oil came out the spindles before starting. After several bursts of running, starting round 10 seconds then building up to a minute or two, oil is coming out the spindles/pivots but not very much. Should I expect lots of oil to be coming out the rockers, or not much?
There is plenty coming out the return pipe in the tank. Maybe the pressure valve needs loooking at?
Second, the amal monobloc has a tiny hole on the underside of the flange, that mounts to the head. I only noticed cos after it stopped exhaust fumes came out. Should it be there? I'll try and get a pic up tomorrow.
Finally, any tips on running in?
