Thick and Thin Crankshaft Distance Washers
Posted: Mon May 27, 2013 10:56 pm
by Connie1959
Hi Everybody,
I´m just trying to rebuild a 350cc Bullet engine out of a basket case of 70s parts.
While checking all the parts I struggled about different crankshaft distance washers.
Can anybody tell me if I need the thin or the thick ones for a 350cc engine?
Thanks,
Connie1959
Posted: Tue May 28, 2013 10:24 am
Do you mean the thrust washers either side of the big end and the flywheels? If so it should be easy to work out, the big end journal is a straight sided press fit into the flywheels, if you measure the distance between the shoulder of the pin and the bearing cage then divide by two, you have your answer. A small free play allowance (say 5 thou total) should be factored in.
Posted: Tue May 28, 2013 6:07 pm
by Connie1959
Hi Mark,
thanks for your reply. Gonna have a look.
Best regards
