By Craig
#2204
My 350 AVL (Based on the Electra) has the 5 Speed Gear Box,Left Foot Change!.....Q:Now on The Clutch Leaver They is No Fine adjustment?..No Lock Ring or Knurl nut..... IS They A Logical Reason For This?......I Have Noticed this On Some Other 5 Speed Electra's,,,,,
Lastly My 5 Speed has the awfull Routed Cable Prob, Before I Re route and Have a Play..Any Advice on the 5 Speed Box/Clutch set up?,,,,, Cheers Craig
#25102
Craig, they don't have the thumbscrew adjuster and if the clutch is setup and adjusted correctly it should work ok, nothing fantastic but ok
By Craig
#25118
Hi Norm,
To get it anything Like Ok ..The Bottom adjuster Is Sticking out The Gear Box Casing At Least 1" (25mm)..Is This Right??
Cheers Craig
#25121
Hi Craig, if the adjuster is still in the thread I would say it is ok, there's a couple of cables and if it is an early box it may have the clutch arm in the box without the swivel. If this cable has gone out of adjustment recently better check that the cable isn't starting to break either in the box or up on the handelbar
